ArcGIS.Desktop.Layouts Namespace / LayoutView Class / ScreenToPage Method
The point value in screen coordinates.
    ScreenToPage Method (LayoutView)
    Converts a point in screen coordinates to a point in page coordinates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Coordinate2D ScreenToPage(
       Point screenPoint
    Public Function ScreenToPage( _
       ByVal screenPoint As Point _
    ) As Coordinate2D
    Parameters
    screenPoint
    Return Value
    The converted point in page coordinates.
    Exceptions
    ExceptionDescription
    Remarks
    Page coordinates will be in the current units of the page. If either screen coordinate value is double.NaN then a coordinate with X, Y both set to System.Double.NaN is returned.
    Requirements
