ArcGIS.Desktop.Layouts Namespace / LayoutView Class / ZoomToElements Method
The set of elements to zoom to.
The amount of time to navigate the view to the new camera position. If null it uses the default navigation duration.
Example
    ZoomToElements Method (LayoutView)
    Zoom to the extent of the elements. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function ZoomToElements( _
       ByVal elements As IEnumerable(Of Element), _
       Optional ByVal duration As Nullable(Of TimeSpan) _
    ) As Boolean
    Parameters
    elements
    duration
    Return Value
    Returns true if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    The value cannot be null: elements
    Example
    Zoom to elements
      LayoutView lytView = LayoutView.Active;
      //Zoom to an element
      var elementToZoomTo = layout.FindElements(new List<string>() { "MyPoint" }).FirstOrDefault();
      lytView.ZoomToElement(elementToZoomTo);
      //Zoom to  multiple elements.
      var elementsToZoomTo = layout.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
      lytView.ZoomToElements(elementsToZoomTo);
    Requirements
