ArcGIS.Desktop.Reports Namespace / Report Class / MoveReportSectionElement Method
The report section element.
The new index location.
    Moves the report section element to new index location. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub MoveReportSectionElement( _
       ByVal reportSectionElement As ReportSectionElement, _
       ByVal newIndex As Integer _
    public void MoveReportSectionElement(
       ReportSectionElement reportSectionElement,
       int newIndex
    Parameters
    newIndex
    Exceptions
    ExceptionDescription
    The section must be a report section or supplemental page section.
    The newIndex parameter is out of range.
    Requirements
