ArcGIS.Desktop.Reports Namespace / ReportElementFactory Class / CreateAttachmentFrame Method
IElementContainer
Envelope
    CreateAttachmentFrame Method (ReportElementFactory)
    Creates an attachment frame element on a report from an envelope geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CreateAttachmentFrame( _
       ByVal elementContainer As IElementContainer, _
       ByVal envelope As Envelope _
    ) As AttachmentFrame
    Parameters
    elementContainer
    IElementContainer
    envelope
    Envelope
    Return Value
    Exceptions
    ExceptionDescription
    Invalid report section.
    Invalid report.
    Element extents outside section.
    Attachment frame elements only valid in details section.
    Failed to create attachment frame.
    Remarks
    The element gets added to the group at the topmost position.
    Requirements
