ArcGIS.Desktop.Reports Namespace / ReportElementFactory Class / CreateChartFrame Method
IElementContainer
Envelope
    CreateChartFrame Method (ReportElementFactory)
    Creates a chartFrame element on a report from an envelope geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    elementContainer
    IElementContainer
    envelope
    Envelope
    mapMember
    chartName
    Return Value
    Returns a ChartFrame.
    Exceptions
    ExceptionDescription
    Invalid report section.
    Invalid report.
    Element extents outside section.
    Cannot add chart frame to this section type.
    Failed to create chart frame.
    Remarks
    The element gets added to the group at the topmost position.
    Requirements
