public static IReportElementFactory Instance {get;}
Public Shared ReadOnly Property Instance As IReportElementFactory
//This is the gap between two fields
double fieldIncrement = 0.9388875113593206276389;
await QueuedTask.Run(() =>
//New field to add.
var newReportField = new CIMReportField
Name = "POP1990",
FieldOrder = 2,
//Get the "ReportSection element"
var mainReportSection = report.Elements.OfType<ReportSection>().FirstOrDefault();
if (mainReportSection == null)
return;
//Get the "ReportDetails" within the ReportSectionElement. ReportDetails is where "fields" are.
var reportDetailsSection = mainReportSection?.Elements.OfType<ReportDetails>().FirstOrDefault();
if (reportDetailsSection == null)
return;
//Within ReportDetails find the envelope that encloses a field.
//We get the first CIMParagraphTextGraphic in the collection so that we can add the new field next to it.
var lastFieldGraphic = reportDetailsSection.Elements.FirstOrDefault((r) =>
var gr = r as GraphicElement;
if (gr == null)
return false;
return (gr.GetGraphic() is CIMParagraphTextGraphic ? true : false);
//Get the Envelope of the last field
var graphicBounds = lastFieldGraphic.GetBounds();
//Min and Max values of the envelope
var xMinOfFieldEnvelope = graphicBounds.XMin;
var yMinOfFieldEnvelope = graphicBounds.YMin;
var xMaxOfFieldEnvelope = graphicBounds.XMax;
var YMaxOfFieldEnvelope = graphicBounds.YMax;
//create the new Envelope to be offset from the existing field
MapPoint newMinPoint = MapPointBuilderEx.CreateMapPoint(xMinOfFieldEnvelope + fieldIncrement, yMinOfFieldEnvelope);
MapPoint newMaxPoint = MapPointBuilderEx.CreateMapPoint(xMaxOfFieldEnvelope + fieldIncrement, YMaxOfFieldEnvelope);
Envelope newFieldEnvelope = EnvelopeBuilderEx.CreateEnvelope(newMinPoint, newMaxPoint);
//Create field
GraphicElement fieldGraphic = ReportElementFactory.Instance.CreateFieldValueTextElement(reportDetailsSection, newFieldEnvelope, newReportField);
