ArcGIS.Desktop.Reports Namespace / ReportView Class / ZoomTo Method
The geometry defining the extent in which to pan.
Example
    ZoomTo Method (ReportView)
    Zoom the report view to the extent defined by a geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function ZoomTo( _
       ByVal geometry As Geometry _
    ) As Boolean
    public bool ZoomTo(
       Geometry geometry
    Parameters
    geometry
    Return Value
    Returns true if the navigation is completed, false if it was interrupted by another view navigation.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Example
    Zoom to specific location on Report view
      //Note: On the QueuedTask
      var detailsSection = report.Elements.OfType<ReportSection>().FirstOrDefault().Elements.OfType<ReportDetails>().FirstOrDefault();
      var bounds = detailsSection.GetBounds();
      ReportView.Active.ZoomTo(bounds);
    Requirements
