ArcGIS.Desktop.Mapping Namespace / MapMember Class / GetMetadata Method
Example
    GetMetadata Method (MapMember)
    Gets the MapMember metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overridable Function GetMetadata() As String
    public virtual string GetMetadata()
    Return Value
    The xml formatted metadata
    Exceptions
    ExceptionDescription
    Example
    Layer Metadata
        //Search for only layers/tables here if needed.
        MapMember mapMember = map.GetLayersAsFlattenedList().FirstOrDefault();
        if (mapMember == null) return;
        //Note: Run within a QueuedTask
        //Gets whether or not the MapMember stores its own metadata or uses metadata retrieved
        //from its source. This method must be called on the MCT. Use QueuedTask.Run
        bool doesUseSourceMetadata = mapMember.GetUseSourceMetadata();
        //Sets whether or not the MapMember will use its own metadata or the metadata from
        //its underlying source (if it has one). This method must be called on the MCT.
        //Use QueuedTask.Run
        mapMember.SetUseSourceMetadata(true);
        //Does the MapMember supports metadata
        var supportsMetadata = mapMember.SupportsMetadata;
        //Get MapMember metadata
        var metadatstring = mapMember.GetMetadata();
        //TODO:Make edits to metadata using the retrieved mapMetadata string.
        //Set the modified metadata back to the mapmember (layer, table..)
        if (mapMember.GetCanEditMetadata())
            mapMember.SetMetadata(metadatstring);
    Requirements
