Public Overridable Sub SetMetadata( _ ByVal metadataXml As String _ )
public virtual void SetMetadata( string metadataXml )
Parameters
- metadataXml
- The xml formatted metadata
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.Xml.XmlException | There is a load or parse error in the XML |
//Search for only layers/tables here if needed.
MapMember mapMember = map.GetLayersAsFlattenedList().FirstOrDefault();
if (mapMember == null) return;
//Note: Run within a QueuedTask
//Gets whether or not the MapMember stores its own metadata or uses metadata retrieved
//from its source. This method must be called on the MCT. Use QueuedTask.Run
bool doesUseSourceMetadata = mapMember.GetUseSourceMetadata();
//Sets whether or not the MapMember will use its own metadata or the metadata from
//its underlying source (if it has one). This method must be called on the MCT.
//Use QueuedTask.Run
mapMember.SetUseSourceMetadata(true);
//Does the MapMember supports metadata
var supportsMetadata = mapMember.SupportsMetadata;
//Get MapMember metadata
var metadatstring = mapMember.GetMetadata();
//TODO:Make edits to metadata using the retrieved mapMetadata string.
//Set the modified metadata back to the mapmember (layer, table..)
if (mapMember.GetCanEditMetadata())
mapMember.SetMetadata(metadatstring);
