ArcGIS.Desktop.Mapping Namespace / MapMember Class / SupportsMetadata Property
Example
    SupportsMetadata Property (MapMember)
    Gets whether the MapMember supports metadata
    Syntax
    Public Overridable ReadOnly Property SupportsMetadata As Boolean
    public virtual bool SupportsMetadata {get;}
    Remarks
    Calling any method on IMetadataInfo on a MapMember that does not support metadata will result in a System.NotSupportedException
    Example
    Layer Metadata
        //Search for only layers/tables here if needed.
        MapMember mapMember = map.GetLayersAsFlattenedList().FirstOrDefault();
        if (mapMember == null) return;
        //Note: Run within a QueuedTask
        //Gets whether or not the MapMember stores its own metadata or uses metadata retrieved
        //from its source. This method must be called on the MCT. Use QueuedTask.Run
        bool doesUseSourceMetadata = mapMember.GetUseSourceMetadata();
        //Sets whether or not the MapMember will use its own metadata or the metadata from
        //its underlying source (if it has one). This method must be called on the MCT.
        //Use QueuedTask.Run
        mapMember.SetUseSourceMetadata(true);
        //Does the MapMember supports metadata
        var supportsMetadata = mapMember.SupportsMetadata;
        //Get MapMember metadata
        var metadatstring = mapMember.GetMetadata();
        //TODO:Make edits to metadata using the retrieved mapMetadata string.
        //Set the modified metadata back to the mapmember (layer, table..)
        if (mapMember.GetCanEditMetadata())
            mapMember.SetMetadata(metadatstring);
    Requirements
