await QueuedTask.Run(() =>
//Must be a .NetCDF file for voxels
var url = @"C:\MyData\AirQuality_Redlands.nc";
var cim_connection = new CIMVoxelDataConnection()
URI = url
//Create a VoxelLayerCreationParams
var createParams = VoxelLayerCreationParams.Create(cim_connection);
createParams.IsVisible = true;
//Can also just use the path directly...
//var createParams = VoxelLayerCreationParams.Create(url);
//Use VoxelLayerCreationParams to enumerate the variables within
//the voxel
var variables = createParams.Variables;
foreach (var variable in variables)
var line = $"{variable.Variable}: {variable.DataType}, " +
$"{variable.Description}, {variable.IsDefault}, {variable.IsSelected}";
System.Diagnostics.Debug.WriteLine(line);
//Optional: set the default variable
createParams.SetDefaultVariable(variables.Last());
//Create the layer - map must be a local scene
voxelLayer = LayerFactory.Instance.CreateLayer<VoxelLayer>(createParams, map);
