ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVariableProfile Class / DeleteIsosurface Method
The definition of the isosurface to delete.
Example
    Delete the specified isosurface. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void DeleteIsosurface(
       IsosurfaceDefinition isosurfaceDef
    Public Sub DeleteIsosurface( _
       ByVal isosurfaceDef As IsosurfaceDefinition _
    Parameters
    isosurfaceDef
    Exceptions
    ExceptionDescription
    Isosurface not found in the collection of isosurfaces.
    Example
    Delete Isosurfaces
      await QueuedTask.Run(() =>
        var variable = voxelLayer.SelectedVariableProfile;
        //delete the last surface
        var last_surface = variable.GetIsosurfaces().LastOrDefault();
        if (last_surface != null)
          variable.DeleteIsosurface(last_surface);
        //delete all the surfaces
        foreach (var surface in variable.GetIsosurfaces())
          variable.DeleteIsosurface(surface);
        //Optional - set visualization back to Volume
        if (variable.GetIsosurfaces().Count() == 0)
          voxelLayer.SetVisualization(VoxelVisualization.Volume);
    Requirements
