ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVariableProfile Class / GetIsosurfaceColor Method
The value to return the color for
Example
    Gets the corresponding isosurface color for the specific value. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public CIMColor GetIsosurfaceColor(
       double value
    Public Function GetIsosurfaceColor( _
       ByVal value As Double _
    ) As CIMColor
    Parameters
    value
    Return Value
    Remarks
    The returned color is controlled by the color range and color scheme of the underlying variable profile's renderer
    Example
    Change Isourface Color Back to Default
      var variable = voxelLayer.SelectedVariableProfile;
      //Change the color of the first surface for the given profile
      var surface = variable.GetIsosurfaces().FirstOrDefault();
      await QueuedTask.Run(() =>
        if (surface.IsCustomColor)
          surface.Color = variable.GetIsosurfaceColor((double)surface.Value);
          surface.IsCustomColor = false;
          //update the surface
          variable.UpdateIsosurface(surface);
    Requirements
