ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVariableProfile Class / GetIsosurfaces Method
Example
    Gets the collection of isosurfaces
    Syntax
    public IList<IsosurfaceDefinition> GetIsosurfaces()
    Public Function GetIsosurfaces() As IList(Of IsosurfaceDefinition)
    Remarks
    Isosurfaces are created for specific (continuous) variable profiles
    Example
    Check the MaxNumberofIsoSurfaces for a Variable
      var variable = voxelLayer.GetVariableProfiles().First();
      var max = variable.MaxNumberOfIsosurfaces;
      if (max >= variable.GetIsosurfaces().Count)
        //no more surfaces can be created on this variable
    How to Change Value and Color on an Isosurface
      await QueuedTask.Run(() =>
        var variable = voxelLayer.SelectedVariableProfile;
        //Change the color of the first surface for the given profile
        var surface = variable.GetIsosurfaces().FirstOrDefault();
        if (surface != null)
          if (voxelLayer.Visualization != VoxelVisualization.Surface)
            voxelLayer.SetVisualization(VoxelVisualization.Surface);
          //Change the iso surface voxel value
          surface.Value = surface.Value * 0.9;
          //get a random color
          var count = new Random().Next(0, 100);
          var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
            ((CIMVoxelStretchRenderer)variable.Renderer).ColorRamp, count);
          var idx = new Random().Next(0, count - 1);
          surface.Color = colors[idx];
          //set the custom color flag true to lock the color
          //locking the color prevents it from being changed if the
          //renderer color range or color theme is updated
          surface.IsCustomColor = true;
          //update the surface
          variable.UpdateIsosurface(surface);
    Change Isourface Color Back to Default
        if (surface.IsCustomColor)
          surface.Color = variable.GetIsosurfaceColor((double)surface.Value);
          surface.IsCustomColor = false;
    Delete Isosurfaces
        //delete the last surface
        var last_surface = variable.GetIsosurfaces().LastOrDefault();
        if (last_surface != null)
          variable.DeleteIsosurface(last_surface);
        //delete all the surfaces
        foreach (var surface in variable.GetIsosurfaces())
          variable.DeleteIsosurface(surface);
        //Optional - set visualization back to Volume
        if (variable.GetIsosurfaces().Count() == 0)
          voxelLayer.SetVisualization(VoxelVisualization.Volume);
    Requirements
