public void SetRenderer( CIMVoxelRenderer renderer )
Public Sub SetRenderer( _ ByVal renderer As CIMVoxelRenderer _ )
Parameters
- renderer
- The renderer to be set.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
//Typically, the default color range covers the most
//commonly occurring voxel values. Usually, the data
//range is much broader than the color range
await QueuedTask.Run(() =>
//Get the variable profile whose renderer will be changed
var variable = voxelLayer.SelectedVariableProfile;
//Check DataType
if (variable.DataType != VoxelVariableDataType.Continuous)
//must be continuous to have a Stretch Renderer...
var renderer = variable.Renderer as CIMVoxelStretchRenderer;
var color_min = renderer.ColorRangeMin;
var color_max = renderer.ColorRangeMax;
//increase range by 10% of the current difference
var dif = (color_max - color_min) * 0.05;
color_min -= dif;
color_max += dif;
//make sure we do not exceed data range
if (color_min < variable.Statistics.MinimumValue)
color_min = variable.Statistics.MinimumValue;
if (color_max > variable.Statistics.MaximumValue)
color_max = variable.Statistics.MaximumValue;
//variable.Statistics.MinimumValue
renderer.ColorRangeMin = color_min;
renderer.ColorRangeMax = color_max;
//apply changes
variable.SetRenderer(renderer);
//Check DataType
if (variable.DataType != VoxelVariableDataType.Discrete)
return;//must be Discrete to have a UV Renderer...
var renderer = variable.Renderer as CIMVoxelUniqueValueRenderer;
//A CIMVoxelUniqueValueRenderer consists of a collection of
//CIMVoxelColorUniqueValue classes - one per discrete value
//in the associated variable profile value array
//Get the first class
var classes = renderer.Classes.ToList();
var unique_value_class = classes.First();
//Set its visibility off
unique_value_class.Visible = false;
//Apply the change to the renderer
renderer.Classes = classes.ToArray();
//apply the changes
