ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVariableProfile Class / UpdateIsosurface Method
The definition of the isosurface to update
Example
    Update the specified isosurface. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void UpdateIsosurface(
       IsosurfaceDefinition isosurfaceDef
    Public Sub UpdateIsosurface( _
       ByVal isosurfaceDef As IsosurfaceDefinition _
    Parameters
    isosurfaceDef
    Exceptions
    ExceptionDescription
    Invalid isosurface definition specified.
    Isosurface not found in the collection of surfaces
    Example
    How to Change Value and Color on an Isosurface
      await QueuedTask.Run(() =>
        var variable = voxelLayer.SelectedVariableProfile;
        //Change the color of the first surface for the given profile
        var surface = variable.GetIsosurfaces().FirstOrDefault();
        if (surface != null)
          if (voxelLayer.Visualization != VoxelVisualization.Surface)
            voxelLayer.SetVisualization(VoxelVisualization.Surface);
          //Change the iso surface voxel value
          surface.Value = surface.Value * 0.9;
          //get a random color
          var count = new Random().Next(0, 100);
          var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
            ((CIMVoxelStretchRenderer)variable.Renderer).ColorRamp, count);
          var idx = new Random().Next(0, count - 1);
          surface.Color = colors[idx];
          //set the custom color flag true to lock the color
          //locking the color prevents it from being changed if the
          //renderer color range or color theme is updated
          surface.IsCustomColor = true;
          //update the surface
          variable.UpdateIsosurface(surface);
    Change Isourface Color Back to Default
        if (surface.IsCustomColor)
          surface.Color = variable.GetIsosurfaceColor((double)surface.Value);
          surface.IsCustomColor = false;
    Requirements
