ArcGIS.Desktop.Core.DeviceLocation.Events Namespace / SnapshotChangedEvent Class / Subscribe Method
The delegate that gets executed when the event is published.
When false the ArcGIS.Core.Events.CompositePresentationEvent<TPayload> will maintain a weak delegate reference to the subscriber. Using a weak delegate reference relieves the subscriber from the need to unsubscribe to enable proper garbage collection.
Example
    Subscribe Method (SnapshotChangedEvent)
    Subscribe to the SnapshotChangedEvent.
    Syntax
    Parameters
    action
    keepSubscriberAlive
    Return Value
    A ArcGIS.Core.Events.SubscriptionToken that uniquely identifies the added subscription.
    Example
    Subscribe to Location Snapshot event
        SnapshotChangedEvent.Subscribe(OnSnapshotChanged);
        /// Handles changes to a snapshot by processing the provided snapshot data.
        void OnSnapshotChanged(SnapshotChangedEventArgs args)
            if (args == null)
                return;
            var snapshot = args.Snapshot as NMEASnapshot;
            if (snapshot == null)
                return;
            //Note: Run within a QueuedTask
            var pt = snapshot.GetPositionAsMapPoint();
            if (pt?.IsEmpty ?? true)
                return;
            // access properties
            var alt = snapshot.Altitude;
            var dt = snapshot.DateTime;
            var vdop = snapshot.VDOP;
            var hdop = snapshot.HDOP;
            // etc
            //TODO: use the snapshot
    Requirements
