ArcGIS.Desktop.Mapping.Voxel Namespace / IsosurfaceDefinition Class / Name Property
Example
    Name Property (IsosurfaceDefinition)
    Gets and sets the isosurface name.
    Syntax
    Public Property Name As String
    public string Name {get; set;}
    Example
    Create Isosurface
      // Note: call within QueuedTask.Run()
        //Visualization must be surface
        if (voxelLayer.Visualization != VoxelVisualization.Surface)
          voxelLayer.SetVisualization(VoxelVisualization.Surface);
        //Get the variable profile on which to create the iso surface
        var variable = voxelLayer.SelectedVariableProfile;
        // o Visualization must be Surface
        // o Variable profile must be continuous
        // o Variable MaxNumberofIsoSurfaces must not have been reached...
        if (variable.CanCreateIsosurface)
          //Note: calling create if variable.CanCreateIsosurface == false
          //will trigger an InvalidOperationException
          //Specify a voxel value for the iso surface
          var min = variable.Statistics.MinimumValue;
          var max = variable.Statistics.MaximumValue;
          var mid = (max + min) / 2;
          //color range (i.e. values that are being rendered)
          var renderer = variable.Renderer as CIMVoxelStretchRenderer;
          var color_min = renderer.ColorRangeMin;
          var color_max = renderer.ColorRangeMax;
          //keep the surface within the current color range (or it
          //won't render)
          if (mid < color_min)
            mid = renderer.ColorRangeMin;
          else if (mid > color_max)
            mid = renderer.ColorRangeMax;
          //Create the iso surface
          var suffix = Math.Truncate(mid * 100) / 100;
          variable.CreateIsosurface(new IsosurfaceDefinition()
            Name = $"Surface {suffix}",
            Value = mid,
            IsVisible = true
    Requirements
