Public Property Value As Nullable(Of Double)
public Nullable<double> Value {get; set;}
// Note: call within QueuedTask.Run()
//Visualization must be surface
if (voxelLayer.Visualization != VoxelVisualization.Surface)
voxelLayer.SetVisualization(VoxelVisualization.Surface);
//Get the variable profile on which to create the iso surface
var variable = voxelLayer.SelectedVariableProfile;
// o Visualization must be Surface
// o Variable profile must be continuous
// o Variable MaxNumberofIsoSurfaces must not have been reached...
if (variable.CanCreateIsosurface)
//Note: calling create if variable.CanCreateIsosurface == false
//will trigger an InvalidOperationException
//Specify a voxel value for the iso surface
var min = variable.Statistics.MinimumValue;
var max = variable.Statistics.MaximumValue;
var mid = (max + min) / 2;
//color range (i.e. values that are being rendered)
var renderer = variable.Renderer as CIMVoxelStretchRenderer;
var color_min = renderer.ColorRangeMin;
var color_max = renderer.ColorRangeMax;
//keep the surface within the current color range (or it
//won't render)
if (mid < color_min)
mid = renderer.ColorRangeMin;
else if (mid > color_max)
mid = renderer.ColorRangeMax;
//Create the iso surface
var suffix = Math.Truncate(mid * 100) / 100;
variable.CreateIsosurface(new IsosurfaceDefinition()
Name = $"Surface {suffix}",
Value = mid,
IsVisible = true
//Change the color of the first surface for the given profile
var surface = variable.GetIsosurfaces().FirstOrDefault();
if (surface != null)
//Change the iso surface voxel value
surface.Value = surface.Value * 0.9;
//get a random color
var count = new Random().Next(0, 100);
var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
((CIMVoxelStretchRenderer)variable.Renderer).ColorRamp, count);
var idx = new Random().Next(0, count - 1);
surface.Color = colors[idx];
//set the custom color flag true to lock the color
//locking the color prevents it from being changed if the
//renderer color range or color theme is updated
surface.IsCustomColor = true;
//update the surface
variable.UpdateIsosurface(surface);
