ArcGIS.Desktop.Mapping.Voxel Namespace / VoxelVariableProfile Class / Variable Property
Example
    Variable Property (VoxelVariableProfile)
    Gets the variable profile variable name.
    Syntax
    public string Variable {get;}
    Public ReadOnly Property Variable As String
    Example
    Subscribe for Changes to a Voxel Layer
      MapMemberPropertiesChangedEvent.Subscribe((args) =>
        var voxel = args.MapMembers.OfType<VoxelLayer>().FirstOrDefault();
        if (voxel == null)
          return;
        //Anything changed on a voxel layer?
        if (args.EventHints.Any(hint => hint == MapMemberEventHint.VoxelSelectedVariable))
          //Voxel variable profile selection changed
          var changed_variable_name = voxel.SelectedVariableProfile.Variable;
          //TODO respond to change, use QueuedTask if needed
        else if (args.EventHints.Any(hint => hint == MapMemberEventHint.Renderer))
          //This can fire when a renderer becomes ready on a new layer; the selected variable profile
          //is changed; visualization is changed, etc.
          var renderer = voxel.SelectedVariableProfile.Renderer;
      VoxelAssetChangedEvent.Subscribe((args) =>
        //An asset changed on a voxel layer
        System.Diagnostics.Debug.WriteLine("");
        System.Diagnostics.Debug.WriteLine("VoxelAssetChangedEvent");
        System.Diagnostics.Debug.WriteLine($" AssetType: {args.AssetType}, ChangeType: {args.ChangeType}");
        if (args.ChangeType == VoxelAssetEventArgs.VoxelAssetChangeType.Remove)
          return;
        //Get "what"changed - add or update
        //eg IsoSurface
        VoxelLayer voxelLayer = null;
        if (args.AssetType == VoxelAssetEventArgs.VoxelAssetType.Isosurface)
          var surface = MapView.Active.GetSelectedIsosurfaces().FirstOrDefault();
          //there will only be one selected...
          if (surface != null)
            voxelLayer = surface.Layer;
        //Repeat for Slices, Sections, LockedSections...
        //GetSelectedSlices(), GetSelectedSections(), GetSelectedLockedSections();
    Get the Selected Variable Profile
      var sel_profile = voxelLayer.SelectedVariableProfile;
      //Get the variable profile name
      var profile_name = sel_profile.Variable;
    Change the Selected Variable Profile
      await QueuedTask.Run(() =>
        var profiles = voxelLayer.GetVariableProfiles();
        //Select any profile as long as it is not the current selected variable
        var not_selected = profiles.Where(p => p.Variable != sel_profile.Variable).ToList();
        if (not_selected.Count() > 0)
          voxelLayer.SetSelectedVariableProfile(not_selected.First());
    Requirements
