ArcGIS.Core.Data.Analyst3D Namespace / TinDataset Class / GetDataTriangleCount Method
    Gets the number of data triangles in this TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDataTriangleCount() As Integer
    public int GetDataTriangleCount()
    Return Value
    The number of data triangles in this TIN.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    A triangle is considered a data triangle if its edges are contained inside or on the boundary of the interpolation zone. To determine if a triangle is a data triangle, use TinTriangle.IsInsideDataArea. When looping through the triangles, the loop starts at index = 1.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
