ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / TinEditor Constructor / TinEditor Constructor(TinDataset)
The TIN that will be edited. If you call SaveEdits, then the original TIN will be modified. If you want to preserve the original TIN, call SaveAs instead, or you can make a copy before you start editing.
Example
    Creates a new TIN editor instance and puts it in edit mode. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function New( _
       ByVal tinDataset As TinDataset _
    public TinEditor(
       TinDataset tinDataset
    Parameters
    tinDataset
    Return Value
    The newly created TIN editor which will be in edit mode.
    Exceptions
    ExceptionDescription
    The required TinDataset is null.
    Example
    Create TinEditor from TinDataset
      TinEditor tinEditorFromDataset = new TinEditor(tinDataset);
      bool isInEditMode = tinEditorFromDataset.IsInEditMode;  // isInEditMode = true
    Edit an existing TIN
      string tinPath = "C:\\Tin"; //original TIN path
      // Create an instance of TinEditor from an existing TinDataset
      tinEditor = new TinEditor(tinDataset);
      int numNodes = tinDataset.GetNodeCount();  // numNodes = 10
      tinEditor.AddPointZ(pointZ, 7);
      // Calling SaveEdits modifies the existing TIN
      tinEditor.SaveEdits();
      numNodes = tinDataset.GetNodeCount();  // numNodes = 11
      // Adding twenty points
      tinEditor.AddMassPoints(points, 10, 112.5);
      // Calling SaveAs creates a new TIN on disk, and
      // the tin editor points to the new TIN.
      string tinPath2 = "C:\\Tin2";
      tinEditor.SaveAs(tinPath2, true);
      tinEditor.StopEditing(true);
      var connection = new FileSystemConnectionPath(new Uri(Path.GetDirectoryName(tinPath2)), FileSystemDatastoreType.Tin);
      using (FileSystemDatastore dataStore = new FileSystemDatastore(connection))
        // See https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-3D-Analyst-Data#working-with-tin-data
        TinDataset tinDataset2 = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(Path.GetFileName(tinPath2));
        numNodes = tinDataset2.GetNodeCount(); // numNodes = 31
      // The edits still show up in the original TIN while it is in memory, but if you open it
      // again you will see that it only has the edits that were saved before SaveAs was called.
      numNodes = tinDataset.GetNodeCount(); // numNodes = 31
      var connection2 = new FileSystemConnectionPath(new Uri(Path.GetDirectoryName(tinPath)), FileSystemDatastoreType.Tin);
        tinDataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(Path.GetFileName(tinPath));
    Requirements
    ArcGIS Pro version: 3.5 or higher.
