ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / AddGeometry Method
The geometry to add.
The surface type which indicates how the polygons are to be incorporated into the tin. The surface types which are valid depend on the type of geometry being entered. Points can only be entered as mass points. Polylines can be entered as hard or soft breakline types or have their vertices entered as mass points. Polygons can be entered as polygon, line, or mass points surface types.
The tag value to be assigned to the new elements in the TIN. If the surface feature type is set to mass points the tag is assigned to the resulting TIN nodes. If the surface type is lineal, then the tags are assigned to edges. If the surface type is polygonal, then the tags are assigned to triangles. A value of 0 will result in no tag assignment.
The z-values for the added geometry. If you want to use the z-values from the input geometry, use AddGeometryZ
Example
    AddGeometry Method (TinEditor)
    Adds a geometry to the TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub AddGeometry( _
       ByVal geometry As Geometry, _
       ByVal tinSurfaceType As TinSurfaceType, _
       ByVal tagValue As Integer, _
       ByVal z As Double _
    Parameters
    geometry
    tinSurfaceType
    tagValue
    z
    Exceptions
    ExceptionDescription
    The geometry is null.
    The geometry is empty.
    The editor is not in edit mode.
    Example
    Add a geometry
      // Add a point as a node with no tag value at height = 10. Points and multipoints can only be added as mass points.
      tinEditor.AddGeometry(mapPoint, TinSurfaceType.MassPoint, 0, 10);
      // Add a z-aware multipoint as a nodes with tag value = 12 at height equal to the z-values of the points. Points and multipoints can only be added as mass points.
      tinEditor.AddGeometryZ(multipointZ, TinSurfaceType.MassPoint, 12);
      // Add a polyline as hard lines with tag value = 42 and height = 17.
      tinEditor.AddGeometry(polyline, TinSurfaceType.HardLine, 42, 17);
      // Add a z-aware polygon as an erase polygon with no tag value and height equal to the z-values of the vertices.
      Polygon polygonZ = PolygonBuilderEx.CreatePolygon(pointsForPolygon); //Define a z-aware polygon
      tinEditor.AddGeometryZ(polygonZ, TinSurfaceType.HardErase, 0);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
