ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / AddPolylinesZ Method
The polylines to add. The z-values from the polylines are used for the TIN.
The surface type which indicates how the polylines are to be incorporated into the tin. Polylines can be entered as hard or soft breakline types or have their vertices entered as mass points.
The tag value to be assigned to the new elements in the TIN. If the surface feature type is set to mass points the tag is assigned to the resulting TIN nodes. If the surface type is lineal, then the tags are assigned to edges. If the surface type is polygonal, then the tags are assigned to triangles. A value of 0 will result in no tag assignment.
The spatial reference of the polylines. If it is the same as the TIN spatial reference, you can pass null. Otherwise, the polylines will be projected from the input spatial reference to the spatial reference of the tin.
Example
    Adds polylines to the TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    polylines
    tinSurfaceType
    tagValue
    spatialReference
    Exceptions
    ExceptionDescription
    The polylines parameter is null.
    The editor is not in edit mode.
    The polylines are all null or empty.
    Example
    Add polylines
      // Add polylines with tagValue = 42 and height = 12.
      // The polylines are in a different spatial reference than the tin editor, so we provide the spatial
      // reference of the polylines. The polylines will be projected to the spatial reference of the tin editor.
      Polyline[] polylines = new Polyline[] //Define some polylines
        PolylineBuilderEx.CreatePolyline(new List<Coordinate2D>
          new Coordinate2D(0,0),
          new Coordinate2D(20,20),
      tinEditor.AddPolylines(polylines, TinSurfaceType.ZLessSoftLine, 42, 12, SpatialReferenceBuilder.CreateSpatialReference(54004));
      // Add z-aware polylines with no tag value. The height comes from the z-values of the vertices.
      // The polylines are in the same spatial reference as the tin editor, so there is no need to provide it.
      Polyline[] polylinesZ = new Polyline[] //Define some z-aware polylines
        PolylineBuilderEx.CreatePolyline(new List<Coordinate3D>
          new Coordinate3D(0,0,5),
          new Coordinate3D(20,20,15),
      tinEditor.AddPolylinesZ(polylinesZ, TinSurfaceType.HardLine, 0);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
