ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / DeleteEdgeTagValues Method
Example
    Deletes all edge tag values in the TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub DeleteEdgeTagValues()
    public void DeleteEdgeTagValues()
    Exceptions
    ExceptionDescription
    The editor is not in edit mode.
    Example
    Delete tag values
      // Delete all edge tags
      tinEditor.DeleteEdgeTagValues();
      // Delete all node tags
      tinEditor.DeleteNodeTagValues();
      // Delete all triangle tags
      tinEditor.DeleteTriangleTagValues();
    Requirements
    ArcGIS Pro version: 3.5 or higher.
