ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / DeleteTriangleTagValues Method
Example
    Deletes all triangle tag values in the TIN. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub DeleteTriangleTagValues()
    public void DeleteTriangleTagValues()
    Exceptions
    ExceptionDescription
    The editor is not in edit mode.
    Example
    Delete tag values
      // Delete all edge tags
      tinEditor.DeleteEdgeTagValues();
      // Delete all node tags
      tinEditor.DeleteNodeTagValues();
      // Delete all triangle tags
      tinEditor.DeleteTriangleTagValues();
    Requirements
    ArcGIS Pro version: 3.5 or higher.
