ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / SetNodeZ Method
The index of the node. Node indices start at 1. The first four nodes are super nodes, so data nodes start with index 5.
The z-value to set. It cannot be NaN.
Example
    SetNodeZ Method
    Sets the z-value of the specified node. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetNodeZ( _
       ByVal index As Integer, _
       ByVal zValue As Double _
    public void SetNodeZ(
       int index,
       double zValue
    Parameters
    index
    zValue
    Exceptions
    ExceptionDescription
    The z-value is NaN.
    The editor is not in edit mode.
    Example
    Set z-value of a node
      // Set the z-value of node #10
      tinEditor.SetNodeZ(10, 12.5);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
