ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / SetToConstrainedDelaunay Method
Example
    Sets the triangulation method to constrained Delaunay from this point forward. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetToConstrainedDelaunay()
    public void SetToConstrainedDelaunay()
    Exceptions
    ExceptionDescription
    The editor is not in edit mode.
    Remarks
    Once this has been set, breaklines will no longer be densified with Steiner points in order to ensure the triangulation conforms to Delaunay criteria. The benefit of having it constrained is you get a best fit match between input and output surface without the need to add densification points. The drawback is the natural neighbors interpolator can't be used on a constrained TIN.
    Once a TIN has been placed in this mode it cannot be changed back by any means other than not saving the edit session used to call this method.
    Example
    Set to constrained Delaunay
      // Set the triangulation method to constrained Delaunay from this point forward
      tinEditor.SetToConstrainedDelaunay();
    Requirements
    ArcGIS Pro version: 3.5 or higher.
