ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / SetTriangleTagValue Method
The index of the triangle. Triangle indices start at 1.
The tag value to set.
Example
    Sets the tag value of the specified triangle. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetTriangleTagValue( _
       ByVal index As Integer, _
       ByVal tagValue As Integer _
    public void SetTriangleTagValue(
       int index,
       int tagValue
    Parameters
    index
    tagValue
    Exceptions
    ExceptionDescription
    The editor is not in edit mode.
    Example
    Set tag values
      // Set the tag value for edge #6
      tinEditor.SetEdgeTagValue(6, 42);
      // Set the tag value for node #8
      tinEditor.SetNodeTagValue(8, 93);
      // Set the tag value for triangle #9
      tinEditor.SetTriangleTagValue(9, 17);
    Requirements
    ArcGIS Pro version: 3.5 or higher.
