ArcGIS.Core.Data.Analyst3D Namespace / TinEditor Class / StopEditing Method
Indicates whether edits should be committed to disk.
If saveEdits is false, the TIN will be returned to the state previous to this edit session. All edits will be undone.
If saveEdits is true, edits from this session will be committed to disk. The TIN must already exist on disk before using this option or else an exception is thrown, and all edits are lost. If the TIN is new and has yet to be saved to disk, Use SaveAs first, then call this method.
Example
    StopEditing Method
    Terminates edit mode. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function StopEditing( _
       ByVal saveEdits As Boolean _
    ) As Boolean
    public bool StopEditing(
       bool saveEdits
    Parameters
    saveEdits
    Return Value
    Returns true if the method succeeds and false otherwise.
    Exceptions
    ExceptionDescription
    The editor is not in edit mode.
    The edits can't be saved because the tin doesn't exist on disk or is invalid.
    Example
    Create a new TIN and save edits
      // Create a new TIN
      tinEditor = new TinEditor(MapView.Active.Extent); // or use any envelope
      tinEditor.AddMassPoints(points, 42, 13.7);
      // Since the TIN doesn't exist on disk, you can't call SaveEdits.
      // You must call SaveAs first.
      try
        tinEditor.SaveEdits();
      catch (TinException)
        // Handle the exception
      // Since the TIN doesn't exist on disk, you can't call StopEditing(true).
      try
        tinEditor.StopEditing(true);
      // Now save the newly created TIN to disk
      tinEditor.SaveAs("C:\\Tin1", false);
      // Delete a node
      tinEditor.DeleteNode(7);
      // Since the TIN now exists on disk you can call SaveEdits
      // Delete another node
      tinEditor.DeleteNode(11);
      // Since the TIN now exists on disk, you can call StopEditing(true).
      // The edits will be saved and the tin editor will be taken out of edit mode.
      bool isInEditMode = tinEditor.IsInEditMode; // isInEditMode = false
      // Now if you try to make an edit, an exception is thrown because the editor is not in edit mode.
      try
        tinEditor.AddPointZ(pointZ, 0);
      // Put the editor into edit mode.
      tinEditor.StartEditing();
      isInEditMode = tinEditor.IsInEditMode; // isInEditMode = true
      // Now you can add the point
      // Oops, you didn't really want to add the point. You want to stop editing and discard the unsaved edits
      // since the last time the editor was put into edit mode. All previous saved edits remain.
      tinEditor.StopEditing(false);
    Edit an existing TIN
      string tinPath = "C:\\Tin"; //original TIN path
      // Create an instance of TinEditor from an existing TinDataset
      tinEditor = new TinEditor(tinDataset);
      int numNodes = tinDataset.GetNodeCount();  // numNodes = 10
      tinEditor.AddPointZ(pointZ, 7);
      // Calling SaveEdits modifies the existing TIN
      numNodes = tinDataset.GetNodeCount();  // numNodes = 11
      // Adding twenty points
      tinEditor.AddMassPoints(points, 10, 112.5);
      // Calling SaveAs creates a new TIN on disk, and
      // the tin editor points to the new TIN.
      string tinPath2 = "C:\\Tin2";
      tinEditor.SaveAs(tinPath2, true);
      var connection = new FileSystemConnectionPath(new Uri(Path.GetDirectoryName(tinPath2)), FileSystemDatastoreType.Tin);
      using (FileSystemDatastore dataStore = new FileSystemDatastore(connection))
        // See https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-3D-Analyst-Data#working-with-tin-data
        TinDataset tinDataset2 = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(Path.GetFileName(tinPath2));
        numNodes = tinDataset2.GetNodeCount(); // numNodes = 31
      // The edits still show up in the original TIN while it is in memory, but if you open it
      // again you will see that it only has the edits that were saved before SaveAs was called.
      numNodes = tinDataset.GetNodeCount(); // numNodes = 31
      var connection2 = new FileSystemConnectionPath(new Uri(Path.GetDirectoryName(tinPath)), FileSystemDatastoreType.Tin);
        tinDataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(Path.GetFileName(tinPath));
    Requirements
    ArcGIS Pro version: 3.5 or higher.
