ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Weed Method
The multipart to generalize.
The maximum deviation used to calculate the deviation used in the Douglas-Peucker generalization algorithm. Cannot be NaN. If maxDeviation is > 0, then internal deviation = maxDeviation * internal tolerance. If maxDeviation is <= 0, then internal deviation = 10000.0 * internal tolerance.
Example
    Weed Method (IGeometryEngine)
    Generalizes the multipart using a small tolerance based upon either the units of the geometry's spatial reference or the geometry's bounding box.
    Syntax
    Parameters
    multipart
    maxDeviation
    Return Value
    The generalized multipart.
    Exceptions
    ExceptionDescription
    The input multipart is null.
    The maxDeviation parameter is NaN.
    Remarks
    For a multipart with non-linear segments, the output multipart may contain more vertices than the input multipart, but all output segments will be linear.
    Example
    Generalize a multipart - Weed
      // generalize with a maxDeviation of 0
      Polyline weedPolyline = GeometryEngine.Instance.Weed(polyline, 0) as Polyline;
      // generalize with a maxDeviation < 0
      weedPolyline = GeometryEngine.Instance.Weed(polyline, -1000000) as Polyline;
      // generalize with a maxDeviation > 0
      weedPolyline = GeometryEngine.Instance.Weed(polyline, 1000000) as Polyline;
    Requirements
    ArcGIS Pro version: 3.5 or higher.
