ArcGIS.Desktop.Editing Namespace / KnowledgeGraphProvenanceDescription Class / KnowledgeGraphProvenanceDescription Constructor / KnowledgeGraphProvenanceDescription Constructor(RowHandle,String,RowHandle,String,String,IReadOnlyDictionary<String,Object>)
The row (existing or future) that this provenance information describes.
The property name that this provenance record describes. Note that this is case-sensitive. You must specify the property name as it is defined in the source table.
The row (existing or future) of the document information from the Document table.
(Optional). Name for the source information.
(Optional). Comments about the source information.
(Optional). The additional attributes for user specified fields to assign the new row in the provenance table.
    Creates a new instance of a KnowledgeGraphProvenanceDescription. Use this constructor for creating provenance records where the Source Type will be set to KnowledgeGraphSourceType.Document and the document is specified using a RowHandle of an existing row or a "to be created" row in the Document table.
    Syntax
    Public Function New( _
       ByVal rowHandle As RowHandle, _
       ByVal propertyName As String, _
       ByVal documentRowHandle As RowHandle, _
       Optional ByVal sourceName As String, _
       Optional ByVal comment As String, _
       Optional ByVal attributes As IReadOnlyDictionary(Of String,Object) _
    Parameters
    rowHandle
    propertyName
    documentRowHandle
    sourceName
    comment
    attributes
    Exceptions
    Requirements
    ArcGIS Pro version: 3.5 or higher.
