ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / AddOverlay Method / AddOverlay(MapView,IEnumerable<CIMGraphic>,Double,Double) Method
The view to add the overlay.
The graphics to be added to the overlay.
Map reference scale or -1
Visibility factor for showing the overlay through other objects when obscured in 3D.
Valid range is [0..1], any other value will be treated as 0 (not visible).
    Add a set of overlay graphics to the map view.
    Syntax
    Public Overloads Shared Function AddOverlay( _
       ByVal mapView As MapView, _
       ByVal graphics As IEnumerable(Of CIMGraphic), _
       ByVal referenceScale As Double, _
       ByVal showThrough As Double _
    ) As IDisposable
    Parameters
    mapView
    graphics
    referenceScale
    showThrough
    Return Value
    An object that when disposed will remove the overlay.
    Remarks
    When the referenceScale is not equal to -1, the overlay will be created in real world units relative to the provided map reference scale (referenceScale). Otherwise, the overlay will be created in units of points. This is only supported in 2D.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
