Public Overloads Shared Function UpdateOverlay( _ ByVal mapView As MapView, _ ByVal disposables As IEnumerable(Of IDisposable), _ ByVal geometries As IEnumerable(Of Geometry), _ ByVal symbol As CIMSymbolReference, _ ByVal referenceScale As Double, _ ByVal showThrough As Double _ ) As Boolean
public static bool UpdateOverlay( MapView mapView, IEnumerable<IDisposable> disposables, IEnumerable<Geometry> geometries, CIMSymbolReference symbol, double referenceScale, double showThrough )
Parameters
- mapView
- The view containing the overlay.
- disposables
- The set of IDisposable instance returned from a group of AddOverlay method calls
- geometries
- The set of geometry to be used for the update
- symbol
- The symbol to use for the update.
- referenceScale
- Map reference scale or -1
- showThrough
- Visibility factor for showing the overlay through other objects when obscured in 3D.
Valid range is [0..1], any other value will be treated as 0 (not visible).
Return Value
True if the overlays were updated. False otherwise.
