ArcGIS.Desktop.Presentations Namespace / PresentationPage Class / CanBringForward Method / CanBringForward(IEnumerable<Element>) Method
The elements to check
    Checks whether the given elements can be moved forward within their parent's element collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CanBringForward( _
       ByVal elements As IEnumerable(Of Element) _
    ) As Boolean
    public bool CanBringForward(
       IEnumerable<Element> elements
    Parameters
    elements
    Return Value
    True if the elements can be moved forward.
    Exceptions
    ExceptionDescription
    elements cannot be null or empty
    Remarks
    Element z order is relative to the element collection within their parent. The bottom element has a z order of 0. The top element has a z order of N - 1. All elements must have the same parent or false is returned. If any one of the elements is already at the top of their parent's element collection, false is returned. False can also be returned if any of the elements' z order cannot be checked (e.g. an element does not belong to a valid presentation page, etc.).
    Requirements
    ArcGIS Pro version: 3.5 or higher.
