ArcGIS.Desktop.Presentations Namespace / PresentationPage Class / CopyElements Method / CopyElements(IEnumerable<Element>) Method
The elements to be copied
    Copy the elements into the presentation page. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CopyElements( _
       ByVal elements As IEnumerable(Of Element) _
    ) As IReadOnlyList(Of Element)
    Parameters
    elements
    Return Value
    Exceptions
    ExceptionDescription
    elements must belong to a valid presentation page
    Remarks
    Only elements from one presentation page can be copied at one time. To copy elements from multiple presentation pages, CopyElements must be called each time.
    If a group element is provided in the list of elements to be copied then the group element and all its children will be copied.
    If a child of a group element is provided in the list in addition to its parent then the parent takes precedence (i.e. the entire group element is copied and not just that child).
    If a child element of a group element is provided in the list but its parent is not then only the child element is copied. The parent of the copied element will become the target group element.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
