ArcGIS.Desktop.Presentations Namespace / PresentationPage Class / DeleteElements Method / DeleteElements(IEnumerable<Element>) Method
The elements being removed
    Deletes the elements from a presentation page. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub DeleteElements( _
       Optional ByVal elements As IEnumerable(Of Element) _
    public void DeleteElements(
       IEnumerable<Element> elements
    Parameters
    elements
    Exceptions
    ExceptionDescription
    elements must belong to a valid presentation page
    Remarks
    If elements is null then all elements are deleted.
    If a group element is provided in the list of elements to be deleted then the group element and all its children will be deleted.
    If a child of a group element is provided in the list in addition to its parent then the parent takes precedence (i.e. the entire group element is deleted and not just that child)
    Requirements
    ArcGIS Pro version: 3.5 or higher.
