ArcGIS.Desktop.Presentations Namespace / PresentationPage Class / GetFlattenedElements Method
Example
    GetFlattenedElements Method (PresentationPage)
    Gets the flattened collection of elements in the container.
    Syntax
    Public Function GetFlattenedElements() As IReadOnlyList(Of Element)
    public IReadOnlyList<Element> GetFlattenedElements()
    Return Value
    A Readonly list of elements.
    Example
    Element selection and navigation
      //Note: Must be on QueuedTask
      // Find specific elements by name
      var ge_rect = page.FindElement("Rectangle") as GraphicElement;
      var elements = new List<string>();
      elements.Add("Text");
      elements.Add("Polygon");
      var elems = page.FindElements(elements);
      //Get elements retaining hierarchy
      var top_level_elems = page.GetElements();
      //Flatten hierarchy
      var all_elems = page.GetFlattenedElements();
      //Use LINQ with any of the collections
      //Retrieve just those elements that are Visible
      var some_elems = all_elems.Where(ge => ge.IsVisible).ToList();
    Element selection manipulation
      //Select/unselect some elements...
      var elems = activePage.GetFlattenedElements();
      //select any element not a group element
      activePage.SelectElements(elems.Where(e => !e.Name.StartsWith("Group")));
      activePage.UnSelectElements(elems.Where(e => !e.Name.StartsWith("Group")));
      //Select/unselect all visible, graphic elements
      var ge_elems = elems.Where(ge => ge.IsVisible).ToList();
      activePage.SelectElements(ge_elems);
      activePage.UnSelectElements(ge_elems);
      //Select/unselect a specific element
      var na = activePage.FindElement("My Text Element");
      activePage.SelectElement(na);
      activePage.UnSelectElement(na);
      //Select everything
      activePage.SelectElements(elems);
      //enumerate the selected elements
      foreach (var sel_elem in activePage.GetSelectedElements())
        //TODO
    Requirements
    ArcGIS Pro version: 3.5 or higher.
