Public NotInheritable Class PresentationView
public sealed class PresentationView
A project can contain multiple presentations. A presentation view is a pane that displays the view of a presentation. Presentation views are the primary interface used to display, navigate, and select presentation page elements. The presentation being visualized in the view can be accessed via the Presentation property.
There can be multiple presentation views open at a given time, but there can only be one active presentation view. The active presentation view will set the context for the ribbon and many of the dock panes in the application. The Active property will return null if there is no active presentation view.
The presentation view has several "ZoomTo" navigation methods and it also provides the context for managing selected items in the Contents pane. For example, the GetSelectedElements method returns a collection of selected page presentation elements.
//Assume we want to open a view for a particular presentation or activate a view if one is already open
//A presentation project item is an item that appears in the Presentation folder in the Catalog pane.
PresentationProjectItem presentationItem = Project.Current.GetItems<PresentationProjectItem>()
.FirstOrDefault(item => item.Name.Equals("Presentation Name"));
//Note: Must be on QueuedTask.Run
//Reference a presentation associated with a presentation project item
if (presentationItem != null)
//Get the presentation associated with the presentationItem
Presentation presentationToOpen = presentationItem.GetPresentation();
//Next check to see if a presentation view is already open that references the presentation
foreach (var pane in ProApp.Panes)
var prePane = pane as IPresentationPane;
if (prePane == null) // Not a presentation view, continue to the next pane
continue;
//if there is a match, activate the view
if (prePane.PresentationView.Presentation == presentationToOpen)
(prePane as Pane).Activate();
return;
//No pane found, activate a new one - must be called on UI
IPresentationPane iNewPresentationPane = await ProApp.Panes.CreatePresentationPaneAsync(presentationToOpen); //GUI thread
Presentation presentationActive = PresentationView.Active.Presentation;
// Note: Must be on QueuedTask
// add a blank page with with title and paragraph body text element
presentation.AddBlankPage(BlankPageTemplateType.TitleAndParagraph, -1);
//For UI context changes associated with a presentation, subscribe to the PresentationView
//event - views activated/deactivated, views opened/closed
ArcGIS.Desktop.Presentations.Events.PresentationViewEvent.Subscribe((args) =>
//get the affected view and presentation
var view = args.PresentationView;
var presentation = args.PresentationView?.Presentation;
if (presentation == null)
//FYI presentationview and/or presentation can be null...
//eg closed, deactivation
//Check what triggered the event and take appropriate action
switch (args.Hint)
case PresentationViewEventHint.Activated:
// Presentation view activated
break;
case PresentationViewEventHint.Opened:
//A PresentationView has been initialized and opened
break;
case PresentationViewEventHint.Deactivated:
// Presentation view deactivated
break;
case PresentationViewEventHint.Closing:
//Set args.Cancel = true to prevent closing
break;
case PresentationViewEventHint.ExtentChanged:
//presentation view extent has changed
break;
case PresentationViewEventHint.DrawingComplete:
break;
case PresentationViewEventHint.PauseDrawingChanged:
break;
System.Object
ArcGIS.Desktop.Presentations.PresentationView
