| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.InvalidOperationException | Bad or missing GeometryUri. Conversion to geometry failed |
var us_parks = map.GetLayersAsFlattenedList()
.OfType<FeatureLayer>().First(l => l.Name == "USNationalParks");
//enumerate the layer's definition queries - if any
var def_queries = us_parks.DefinitionQueries;
foreach (var def_qry in def_queries)
var geom_uri = def_qry.GeometryUri ?? "null";
var sr_wkid = def_qry.SpatialReference?.Wkid.ToString() ?? "null";
var geom = def_qry.GetFilterGeometry();
var geom_type = geom?.GeometryType.ToString() ?? "null";
System.Diagnostics.Debug.WriteLine($" def_qry.Name: {def_qry.Name}");
System.Diagnostics.Debug.WriteLine($" def_qry.WhereClause: {def_qry.WhereClause}");
System.Diagnostics.Debug.WriteLine($" def_qry.GeometryUri: {geom_uri}");
System.Diagnostics.Debug.WriteLine($" def_qry.SpatialReference: {sr_wkid}");
System.Diagnostics.Debug.WriteLine($" def_qry.FilterGeometry: {geom_type}");
System.Diagnostics.Debug.WriteLine("");
