public class ElevationProfileStatistics
Public Class ElevationProfileStatistics
// subscribe to the Added, Removed events for the elevation profile graph
mapView.ElevationProfileGraphAdded += Mv_ElevationProfileGraphAdded;
mapView.ElevationProfileGraphRemoved += Mv_ElevationProfileGraphRemoved;
//Handles the event triggered when an elevation profile graph is removed.
void Mv_ElevationProfileGraphRemoved(object sender, EventArgs e)
//TODO: handle the removal of the elevation profile graph
//Handles the event triggered when an elevation profile graph is added to the active map view.
void Mv_ElevationProfileGraphAdded(object sender, EventArgs e)
// get the elevation profile graph from the view
// this will be non-null since we are in a ElevationProfileGraphAdded handler
var mv = MapView.Active;
var graph = mv.GetElevationProfileGraph();
// subscribe to the ContentLoaded event
graph.ContentLoaded += Graph_ContentLoaded;
// Handles the event triggered when the elevation profile graph content is loaded.
void Graph_ContentLoaded(object sender, EventArgs e)
var graph = sender as ArcGIS.Desktop.Mapping.ElevationProfileGraph;
// get the elevation profile geometry
var polyline = graph.Geometry;
// get the elevation profile statistics
var stats = graph.ElevationProfileStatistics;
var elevProfileGraph = MapView.Active.GetElevationProfileGraph();
// Elevation profile graph will be null if no profile graph is displayed
if (elevProfileGraph == null)
return;
// get the elevation profile geometry and stats
var polyline = elevProfileGraph.Geometry;
var stats = elevProfileGraph.ElevationProfileStatistics;
// reverse the graph
elevProfileGraph.IsReversed = !elevProfileGraph.IsReversed;
// collapse the graph
elevProfileGraph.IsExpanded = false;
System.Object
ArcGIS.Desktop.Mapping.ElevationProfileStatistics
