ArcGIS.Desktop.Mapping Namespace / FeatureOutlineType Enumeration
Example Example
    Defines which feature geometries will be included in the return type
    Syntax
    Members
    MemberDescription
    AllAll feature geometries wil be included
    SelectedOnly selected feature geometries will be included
    VisibleOnly visible selected feature geometries within the current view extent will be included
    Example
    Querying a feature layer with a spatial filter
        var layers = map.GetLayersAsFlattenedList().OfType<FeatureLayer>();
        var layerToQuery = layers.FirstOrDefault(f => f.Name == "USNationalParks");
        if (layerToQuery == null) return;
        string whereClause = "RecreationVisitsTotal > 1000000"; //More than million visitors a year
        var spatialDefnLayer = layers.FirstOrDefault(f => f.Name == "AllUSStates");
        if (spatialDefnLayer == null) return;
        try
            if (MapView.Active == null) return;
            //Note: needs to be called on the MCT
            // Set the spatial filter geometry
            //Get the geometry from the selected features in the feature layer
            var spatialClauseGeom = spatialDefnLayer.GetFeatureOutline(MapView.Active, FeatureOutlineType.Selected);
            //Create the definition query
            DefinitionQuery definitionQuery = new DefinitionQuery
                WhereClause = whereClause,
                Name = $"{layerToQuery.Name}"
            //Setting the spatial filter to the Definition Query
            if (definitionQuery.CanSetFilterGeometry(spatialClauseGeom))
                definitionQuery.SetFilterGeometry(spatialClauseGeom);
            layerToQuery.InsertDefinitionQuery(definitionQuery);
            layerToQuery.SetActiveDefinitionQuery(definitionQuery.Name);
        catch (Exception ex)
            System.Diagnostics.Debug.WriteLine($"Error querying feature layer: {ex.Message}");
    Apply A Definition Query Filter With a Filter Geometry to a Feature Layer
        var greatLakes = map.GetLayersAsFlattenedList()
              .OfType<FeatureLayer>().First(l => l.Name == "Great Lakes");
        var usa_states = map.GetLayersAsFlattenedList()
        .OfType<FeatureLayer>().First(l => l.Name == "US_States");
        //name must be unique
        var def_query = new DefinitionQuery("GreatLakes",
                              "NAME in ('Huron','Michigan','Erie')");
        //create a filter geometry - in this example we will use the outline geometry
        //of all visible features from a us states layer...the filter geometry will be
        //intersected with the layer feature geometry when added to the def query
        var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Visible);
        //other options...
        //var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.All);
        //var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Selected);
        //Geometry must have a valid SR and be point, multi-point, line, or poly
        if (def_query.CanSetFilterGeometry(filter_geom))
            def_query.SetFilterGeometry(filter_geom);
        //Apply the def query
        greatLakes.InsertDefinitionQuery(def_query);
        //Set it active
        greatLakes.SetActiveDefinitionQuery(def_query.Name);
        //or....also - set it active when it is inserted
        //greatLakes.InsertDefinitionQuery(def_query, true);
    Get Feature Outlines from a Feature Layer
        var michigan = map.GetBookmarks().First(b => b.Name == "Michigan");
        //get all features - multiple feature geometries are always returned as a
        //single multi-part
        var all_features_outline = greatLakes.GetFeatureOutline(mapView, FeatureOutlineType.All);
        //or get just the outline of selected features
        var qry = new QueryFilter()
            SubFields = "*",
            WhereClause = "NAME in ('Huron','Michigan','Erie')"
        greatLakes.Select(qry);
        var sel_features_outline = greatLakes.GetFeatureOutline(
        greatLakes.ClearSelection();
        //or just the visible features
        mapView?.ZoomTo(michigan);
        var visible_features_outline = greatLakes.GetFeatureOutline(
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.FeatureOutlineType
    Requirements
    ArcGIS Pro version: 3.5 or higher.
