ArcGIS.Desktop.Core Namespace / CatalogContentType Enumeration
Example Example
    Specifies the content type for the Catalog dock pane
    Syntax
    Members
    MemberDescription
    Computer Show computer content
    Favorites Show favorites content
    Portal Show portal content
    Project Show project content
    Example
    Get the catalog content type currently being shown
      //Gets the Catalog pane
      var catalogWindow = Project.GetCatalogPane() as ICatalogWindow;
      var catContentType = catalogWindow.GetCurrentContentType();
      // use catContentType;
    Set the catalog content type
      if (!catalogWindow.IsActiveWindow)
        //catalog dockpane must be the active window
      //Change the content to whatever is the next tab
      var catContentType = (int)catalogWindow.GetCurrentContentType();
      catContentType++;
      if (catContentType > (int)CatalogContentType.Favorites)
        catContentType = (int)CatalogContentType.Project;
      //Must be on the UI - no QueuedTask!
      catalogWindow.SetContentTypeAsync((CatalogContentType)catContentType);
    Get the secondary portal catalog content
      //Is Portal the content type?
      if (catContentType == CatalogContentType.Portal)
        //check what is the portal content type being shown...
        var secondaryContentType =
          catalogWindow.GetCurrentSecondaryPortalContentType();
        //TODO use secondary portal content type...
    Set the secondary portal catalog content
      //Is portal content being shown?
        var portalContentType = (int)catalogWindow.GetCurrentSecondaryPortalContentType();
        //advance to the next tab
        portalContentType++;
        if (portalContentType > (int)CatalogSecondaryPortalContentType.LivingAtlas)
          portalContentType = (int)CatalogSecondaryPortalContentType.UserContent;
        //set the secondary portal content type
        catalogWindow.SetSecondaryPortalContentTypeAsync(
          (CatalogSecondaryPortalContentType)portalContentType);
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Core.CatalogContentType
    Requirements
    ArcGIS Pro version: 3.6 or higher.
