ArcGIS.Desktop.Mapping Namespace / FeatureLayer Class / GetIsFeatureDrawOrderSupported Method
Example
    GetIsFeatureDrawOrderSupported Method (FeatureLayer)
    Gets whether or not feature drawing order is supported on the layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overridable Function GetIsFeatureDrawOrderSupported() As Boolean
    public virtual bool GetIsFeatureDrawOrderSupported()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Check Whether Feature Drawing Order is Supported
        //Within QueuedTask.Run()
        var supportsFeatureDrawOrder = featureLayer.GetIsFeatureDrawOrderSupported();
    Requirements
    ArcGIS Pro version: 3.6 or higher.
