ArcGIS.Desktop.Mapping Namespace / NitfFeatureSubLayer Class / GetIsFeatureDrawOrderSupported Method
    GetIsFeatureDrawOrderSupported Method (NitfFeatureSubLayer)
    Gets whether or not feature drawing order is supported on the layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public override bool GetIsFeatureDrawOrderSupported()
    Public Overrides NotOverridable Function GetIsFeatureDrawOrderSupported() As Boolean
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    NITF feature layers do not support feature draw order
    Requirements
    ArcGIS Pro version: 3.6 or higher.
