ArcGIS.Core.Data.Knowledge.Analytics Namespace / KnowledgeGraphCentralityResults Class / Scores Property
Example
    Scores Property
    Gets the centrality scores for the entities in the centrality analysis.
    Syntax
    Public ReadOnly Property Scores As KnowledgeGraphCentralityScores
    public KnowledgeGraphCentralityScores Scores {get;}
    Example
    Process Centrality Results
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        //using(var kg = ....) {
        //use defaults...
        var kg_config = new CIMKnowledgeGraphCentralityConfiguration();
        //include all entities from the kg in the subgraph
        //(no filters)
        var kg_subgraph = new CIMKnowledgeGraphSubGraph();
        //include all centrality measures
        CentralityMeasure[] measures = [
          CentralityMeasure.Degree,
    CentralityMeasure.InDegree,
    CentralityMeasure.OutDegree,
    CentralityMeasure.Coreness,
    CentralityMeasure.Betweenness,
    CentralityMeasure.Closeness,
    CentralityMeasure.Harmonic,
    CentralityMeasure.Eigenvector,
    CentralityMeasure.PageRank
        //compute centrality
        var kg_centrality_results = kg.ComputeCentrality(
                                          kg_config, kg_subgraph, measures);
        //output results - results include measure scores for all entities
        //in all types in the subgraph
        System.Diagnostics.Debug.WriteLine("Centrality Results:");
        foreach (var named_type in kg_centrality_results.NamedTypes)
          System.Diagnostics.Debug.WriteLine($"Named type: {named_type}");
          foreach (var uid in kg_centrality_results.GetUidsForNamedType(named_type))
            //measure scores include one score per measure in the input measures array
            var scores = kg_centrality_results.Scores[uid];
            StringBuilder sb = new StringBuilder();
            var sep = "";
            //or use kg_centrality_results.Scores.Measures.Length
            //kg_centrality_results.Scores.Measures is there for convenience
            for (int m = 0; m < measures.Length; m++)
              sb.Append($"{sep}{measures[m].ToString()}: {scores[m]}");
              sep = ", ";
            System.Diagnostics.Debug.WriteLine($"  '{uid}' {sb.ToString()}");
    Output Centrality Results
        ///var kgConfig = ...;
        //var kgSubgraph = ...;
        //var measures = ...;
        //using(var kg = ...) {
        var results = kg.ComputeCentrality(kgConfig, kgSubgraph, measures);
        //loop through each (entity) named type (relates are never included in results)
        foreach (var named_type in results.NamedTypes)
          //Get the entity uids for each named type
          foreach (var uid in results.GetUidsForNamedType(named_type))
            //Get the scores for each uid via the [] indexer on "Scores"
            var scores = results.Scores[uid];
            //There is one score per measure in the input measures array
            //Note: results.Scores.Measures is also provided for convenience...
            //for (int m = 0; m < results.Scores.Measures.Length; m++)
              var score = scores[m];//score for the given measure
                                    //TODO - use measure score
    Requirements
    ArcGIS Pro version: 3.6 or higher.
