ArcGIS.Desktop.Mapping Namespace / MapMember Class / ExportPopupConfiguration Method
The entire file path, including file name, where the .pop file will be exported to.
    Exports the MapMember's current popup configuration to a .pop file. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub ExportPopupConfiguration( _
       ByVal filePath As String _
    public void ExportPopupConfiguration(
       string filePath
    Parameters
    filePath
    Exceptions
    ExceptionDescription
    Thrown when the filePath is null or empty.
    Thrown when the filePath does not end with a .pop extension.
    Thrown when there is no popup configuration available for the MapMember.
    Thrown when there is an error writing the popup configuration to the file.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
