ArcGIS.Desktop.Reports Namespace / ReportCustomTemplateDataSourceInfo Class
Members Example
    Represents the data source, fields, map and chart data for a subreport of a custom template
    Object Model
    ReportCustomTemplateDataSourceInfo ClassCIMDataConnection ClassMapMember ClassTemplateTokenFieldInfoValues Class
    Syntax
    Public Class ReportCustomTemplateDataSourceInfo
    public class ReportCustomTemplateDataSourceInfo
    Example
    Create a report from a custom report template
      //Note: Run within QueuedTask.Run()
      // get the first map in the project
      MapProjectItem item = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(n => n.Name == "Cities");
      if (item == null)
        return;
      Map map = item.GetMap();
      if (map == null)
        return;
      Layer cityLayer = map.FindLayers("U.S. Cities")[0];
      if (cityLayer == null)
        return;
      // load template information
      var templatePath = System.IO.Path.Combine($@"{Project.Current.HomeFolderPath}\TemplateSimpleReportWithTokens.rptt");
      ReportCustomTemplateDefinition templateDef = ReportTemplateManager.GetCustomTemplateDefinition(templatePath);
      if (templateDef == null || templateDef.ReportTemplateDataSourceItems?.Count() < 1)
        return;
      // get template info of first data source (parent) and set its data source
      ReportCustomTemplateDataSourceInfo parentDataSourceInfo = templateDef.ReportTemplateDataSourceItems.ElementAt(0);
      parentDataSourceInfo.SetReportDataSource(cityLayer);
      TemplateTokenFieldInfoValues templateTokenFieldInfoValues = parentDataSourceInfo.TokenInfoValues;
      parentDataSourceInfo.DefinitionQuery = "STATE_NAME = 'Massachusetts'";
      templateTokenFieldInfoValues["[text-field-value-0]"] = "CITY_NAME";
      templateTokenFieldInfoValues["[text-field-name-0]"] = "City";
      templateTokenFieldInfoValues["[numeric-field-value-0]"] = "POP1990";
      templateTokenFieldInfoValues["[numeric-field-name-0]"] = "Population";
      if (templateDef.CanCreateReport())
        // create the report
        report = ReportFactory.Instance.CreateReport("RelateSiblingsFromCode", templateDef);
      //UI thread
      if (report != null)
        //open report
        await FrameworkApplication.Panes.CreateReportPaneAsync(report);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Reports.ReportCustomTemplateDataSourceInfo
    Requirements
    ArcGIS Pro version: 3.6 or higher.
