GetCustomTemplateDefinition Method
Gets the definition of a custom template to be populated and used to create a report. This method must be called on the MCT. Use QueuedTask.Run.
Create a report from a custom report template
await QueuedTask.Run(() =>
// get the first map in the project
MapProjectItem item = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(n => n.Name == "Cities");
if (item == null)
return;
Map map = item.GetMap();
if (map == null)
return;
Layer cityLayer = map.FindLayers("U.S. Cities")[0];
if (cityLayer == null)
return;
// load template information
var templatePath = System.IO.Path.Combine($@"{Project.Current.HomeFolderPath}\TemplateSimpleReportWithTokens.rptt");
ReportCustomTemplateDefinition templateDef = ReportTemplateManager.GetCustomTemplateDefinition(templatePath);
if (templateDef == null || templateDef.ReportTemplateDataSourceItems?.Count() < 1)
return;
// get template info of first data source (parent) and set its data source
ReportCustomTemplateDataSourceInfo parentDataSourceInfo = templateDef.ReportTemplateDataSourceItems.ElementAt(0);
parentDataSourceInfo.SetReportDataSource(cityLayer);
TemplateTokenFieldInfoValues templateTokenFieldInfoValues = parentDataSourceInfo.TokenInfoValues;
parentDataSourceInfo.DefinitionQuery = "STATE_NAME = 'Massachusetts'";
templateTokenFieldInfoValues["[text-field-value-0]"] = "CITY_NAME";
templateTokenFieldInfoValues["[text-field-name-0]"] = "City";
templateTokenFieldInfoValues["[numeric-field-value-0]"] = "POP1990";
templateTokenFieldInfoValues["[numeric-field-name-0]"] = "Population";
if (templateDef.CanCreateReport())
// create the report
report = ReportFactory.Instance.CreateReport("RelateSiblingsFromCode", templateDef);
//UI thread
if (report != null)
//open report
await FrameworkApplication.Panes.CreateReportPaneAsync(report);
ArcGIS Pro version: 3.6 or higher.
