ArcGIS.Core.Data.Knowledge.Analytics Namespace / PathsEntitiesAndRelationships Class / EntityTypes Property
Example
    EntityTypes Property (PathsEntitiesAndRelationships)
    Gets the index of the entity type within the EntityTypeNames array for each entity in EntitiesUIDs.
    Syntax
    Public ReadOnly Property EntityTypes As ULong()
    public ulong[] EntityTypes {get;}
    Example
    List out FFP Results Origin, Destination, Other Entities
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(async () =>
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "List out FFP Results Origin, Destination, Other Entities";
        //set up config
        var results = kg.RunFilteredFindPaths(ffp_config);
        if (results.CountPaths == 0)
          System.Diagnostics.Debug.WriteLine("FFP returned no paths");
          return;
        //print out paths by increasing length, min cost, max cost
        var path_by_len_indices = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingPathLength
                                    .Select(idx => idx.index);
        var path_by_min_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMinPathCost
        var path_by_max_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMaxPathCost
        var x = 0;
        StringBuilder sb = new StringBuilder();
        foreach (var path_indeces in new List<IEnumerable<long>> {
        path_by_len_indices,
        path_by_min_cost,
        path_by_max_cost})
          if (x == 0)
            sb.AppendLine($"Entities by length: {path_by_len_indices.Count()}");
          else if (x == 1)
            sb.AppendLine($"Entities by min cost: {path_by_min_cost.Count()}");
          else if (x == 2)
            sb.AppendLine($"Entities by max cost: {path_by_max_cost.Count()}");
          x++;
          foreach (var path_idx in path_indeces)
            var path = (ResultPath)results.MaterializePath(path_idx);
            sb.AppendLine(
              $"Path[{path_idx}] length: {path.Length}, min: {path.MinCost} max: {path.MaxCost}");
            var sorted_set = new SortedSet<ulong>();
            sorted_set.Add((ulong)path_idx);
            var per = results.ExtractPathsEntitiesAndRelationships(sorted_set);
            var origin_dest_uids = new List<string>();
            var sep = "";
            sb.Append(" Origin EntitiesUIDs: ");
            foreach (var idx in per.PathsOriginEntitiesUIDsIndexes)
              //See 'List out FFP Results by Path Length, Min Cost, Max Cost' for
              //FormatID method above
              var uid = FormatID(per.EntitiesUIDs[idx].ToString());
              origin_dest_uids.Add(uid);
              var origin =
                $"{sep}{per.EntityTypeNames[per.EntityTypes[idx]]}:{uid}";
              sep = ", ";
              sb.Append($"{origin}");
            sb.AppendLine("");
            sep = "";
            sb.Append(" Destination EntitiesUIDs: ");
            foreach (var idx in per.PathsDestinationEntitiesUIDsIndexes)
              var dest =
              sep = ", ";
              sb.Append($"{dest}");
            sb.AppendLine("");
            sep = "";
            var idx2 = 0;
            sb.Append(" Other EntitiesUIDs: ");
            bool wereAnyOthers = false;
            foreach (var raw_uid in per.EntitiesUIDs)
              var uid = FormatID(raw_uid.ToString());
              if (!origin_dest_uids.Contains(uid))
                var other =
                $"{sep}{per.EntityTypeNames[per.EntityTypes[idx2]]}:{uid}";
                sep = ", ";
                sb.Append($"{other}");
                wereAnyOthers = true;
              idx2++;
            if (!wereAnyOthers)
              sb.Append(" <<none>>");
            //sb.AppendLine("");
            var entity_str = sb.ToString();
            System.Diagnostics.Debug.WriteLine(entity_str);
            sb.Clear();
            sep = "";
    Requirements
    ArcGIS Pro version: 3.6 or higher.
